A connection circuit using only 5V power supply
Source: InternetPublisher:黄土马家 Keywords: Power supply BSP operational amplifier Updated: 2021/01/08
It is converted into a pulse width modulation (PWM) signal by the error processing link and output from pin 3 (MC
signal). At the same time, the differential of the position error is also calculated, which represents the movement speed of D and
is selected from pins 6 and 7 for system damping. One of them is proportional to positive speed and the other
is proportional to negative speed. Both signals are converted into analog damping signals in an external op amp
. Another operational amplifier can be used to synthesize the position error and damping signal into an
analog signal, which is used to control the subsequent power amplifier and drive the DC motor. (See Figure
13-17). The gain and damping of the system can be adjusted by the two resistors RD and R. to
optimize the performance of the system.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Tutorial on making your own remote-controlled robotic arm
- Peripheral circuit of automotive motor controller power supply chip
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- How to set up a cheap beam break sensor control distance scene using a reflector
- Manual automatic air compressor control circuit
- Design and analysis of the principle of automatic power-off switch during power outage
- Ultra-short wave item left behind reminder alarm
- Car audio system anti-theft circuit
- Voice controlled flash LED light circuit diagram
- Fish pond oxygenation reminder circuit
- Egg warming circuit
- Diode Balanced Mixer Circuit
- Diode square rate detection circuit
- ring amplitude modulation circuit
- superheterodyne radio circuit
- High and low frequency signal generator circuit
- Guest arrival signal recognition circuit
- Fault signal trip circuit
