Speed control system with current negative feedback
Source: InternetPublisher:aytwartoofyoroo Keywords: Speed control system error amplifier Updated: 2020/07/01
Another improved solution is to introduce the current feedback signal at the summing point of the error amplifier
and add a current feedback loop. See picture for this plan. In the L292 circuit , the current proportional to the average current of the motor flows through the external circuit
between pin 5 and pin 7. As
shown in the figure, the sample is sampled from the 510fl resistor, amplified and adjusted by an operational amplifier, and then sent
to the error amplifier . 2 feet. The feedback coefficient is set by the potentiometer RP. Properly adjusting
RP can suppress the impact of load current on speed.
- Design of an autonomous plant watering system using ATtiny85
- Build a glove-controlled robotic arm
- What is a RADAX motor?
- Introduction to the internal structure of the Delta winding motor
- Perform surgery on the speaker protection circuit
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Motor self-starting circuit
- Hydraulic control circuit design and analysis
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Vibration anti-theft alarm circuit
- Differential amplifier emitter negative feedback gain control circuit
- Mobile phone camera flash control circuit
- Boiler control circuit
- DC voltage stabilizing circuit and zero-crossing detection circuit in the indoor unit control circuit of Hisense KFR-25GW-06BP inverter air conditioner
- Water dispenser (Aucma) temperature detection control circuit
- audio signal control circuit
- Basic structure of power factor control circuit
- Wide input range non-synchronous voltage mode control circuit
- Power supply circuit with multiple outputs (MAX1902)
- Apply LOGO! Electric gate control circuit b
