HM9901 touch step dimming light circuit
Source: InternetPublisher:蓝猫淘气 Keywords: Touch type dimmer light HM Updated: 2021/09/14
It is a touch-type step-dimming desk lamp made of HM9901 integrated circuit
. When M is touched repeatedly, the brightness of the bulb F changes from dark light to ten, medium light, ten brightest, ten off, dark light, one... and changes cyclically, corresponding to
the conduction of the thyristor VTH. The angles are 1 9 respectively. ,75. ,115. And off.
The HM9901 integrated circuit
is manufactured
using CMOS technology . The power supply voltage
range is 6.8-9V, the
operating current is ≤
0.5mA, the output
current at the output terminal is ≥40mA, and the
maximum oscillation frequency is
300kHz (±∞%). HM 9901 has two package forms: standard DIP
8 and 8-pin black paste soft seal
. The functions of each pin are: ① Pin CK, which is the synchronous clock signal input terminal; ② Pin Fl, which is
the 60Hz/50Hz AC frequency input terminal; ③ Pin Vm is the positive terminal of the power supply; ④ pin TI is the touch sensing input
terminal; ⑤ pin f'I is the sensitivity control input terminal; ⑥ pin se is the circuit status control input terminal; ⑦ pin V. ,,
the negative terminal of the power supply; ⑧ pin AT, is the pulse signal output terminal to drive and trigger the thyristor. If the VTH of this circuit
uses a small plastic bidirectional thyristor such as MAC97A6, it can drive an incandescent bulb below 100W; if the VTH uses
an RTl 3fi bidirectional thyristor, it can drive an incandescent bulb below 200W. If you want to drive a larger load, you can
add an appropriate and secret aluminum heat sink plate to the thyristor 7 or replace it with a bidirectional thyristor with a larger current.
- Experiment on realizing photoelectric alarm using photosensitive devices
- Example of LED AC drive circuit
- DCD-1240 multifunctional rechargeable lighting
- Use NE555 to make a lighting and sound changing circuit
- Corridor automatic light-off device
- Microwave Doppler warning circuit
- Economical and practical delay light circuit
- Automotive LED driver circuit diagram using LT3486
- Fluorescent dimming circuit (1)
- Simple sensor alarm
- SHM1150II integrated power amplifier
- SS0613 touch stepless dimming light circuit
- M668 touch step dimming light circuit
- HT7713 touch step dimming light circuit
- Use CD4011 and CD4017 to make a touch-type five-speed dimmer
- Non-touch delay switch
- Two-way touch switch (3)
- Two-way touch switch (2)
- Touch alarm circuit (2)
- Internal circuit diagram of HM114 thick film circuit
