HM4246 touch step dimming light circuit
Source: InternetPublisher:方世玉223 Keywords: Touch type dimmer light HM Updated: 2021/11/09
A special integrated circuit developed and produced for touch dimming
. It has four touch side light functions of dark, medium, bright and dark. It is a zero-crossing trigger and
has low high-frequency harmonic radiation. It has high touch sensitivity and stability, and can adapt to longer connections and higher sensor load
(-iOOpF). It is mainly used for
brightness adjustment of
desk lamps and other lighting fixtures .
See A1 for its circuit. 34.
The HM4246 integrated circuit adopts standard DIP
8-package, and the functions of each pin
are: ① Pin LK, which is
the clock signal input terminal;
② Pin Fl. It is the 60¨2/
50Hz AC frequency input terminal; ③ pin VT, -, is the positive terminal of the power supply; ④ pin TI. It is the touch sensing input terminal; ⑤
pin CI is the sensitivity control terminal; ⑥ pin N (1, is the empty pin; ⑦ pin V is the negative terminal of the power supply; ⑧ pin AT is the
pulse signal output terminal, which drives the trigger thyristor. HM The power supply voltage range of 4246 is 5~6 SV.
In H, R. RJ-2W metal film resistors are required, and e and c5 should use CBB
type polypropylene capacitors with a voltage resistance of loooV to ensure user safety. [1: , G can use ordinary CD11-16V electrolytic capacitors.
When in use, when the hand touches M repeatedly, the status of the bulb E is: dark light - light - brightest - J light - dark
light -... changes in cycles for selection.
- TEC laser diode driver circuit
- Example of LED AC drive circuit
- Design and production of digital number answering machine
- Corridor automatic light-off device
- Application circuit of CAT3606
- Chandelier brightness controller circuit using thyristor
- Economical and practical delay light circuit
- Two-way electronic music doorbell circuit
- Frost alarm circuit
- Touch lighting switch circuit three
- Touch music electronic doorbell circuit
- Touch lighting delayed light off circuit 2
- SS0622 touch step dimming light circuit
- SS0619 touch step dimming light circuit
- M668 touch step dimming light circuit
- LS7232 touch stepless dimming light circuit
- Touch delay light switch circuit (8)
- Touch Delay Lighting Switch (1)
- Application circuit diagram of dual-axis magnetic field sensor
- Speech synthesis integrated circuit HM2081 and 8031 interface
