Two-way electronic music doorbell circuit
Source: InternetPublisher:elleny Keywords: Doorbell circuit electronic music doorbell power supply short circuit Updated: 2021/12/21
Orientation electronic music doorbell circuit is shown in the figure. When the double-gear button SB1 is pressed in place A, the power phase line passes through SB1, a single outside line, and
passes through the normally closed contact of the SB3 button in place B to form the same path as the neutral line in place B.
At this time, the electric bell in place B sounds. Because while pressing the A button SBI
. The normally closed point of the double-speed button SB1 is disconnected, so the local (A) bell cannot
be energized to make a sound. Similarly, when button SB3 in place B is pressed, only
the bell in place A will be energized to make a sound, and the bell in place B (local) will not make a sound.
This circuit has only one outside line, which has the advantages of saving wires and simple wiring.
During installation, the phase lines connected to ground A and ground B should be the same phase line. If one end is
U phase and the other end is V phase, when both ends press the bell at the same time,
the U and V phases will be short-circuited .
- Build a Bluetooth-controlled wireless scoreboard
- Example of LED AC drive circuit
- Working Principle of CCFL and Analysis of Electronic Driving Circuit
- Measurement and analysis of automatic emergency lighting circuit
- USB powered portable light
- Design and production of rain control and light control timing controller based on P87LPC764
- Use NE555 to make a lighting and sound changing circuit
- Solar battery and charging circuit
- Simple light-controlled street light circuit (7)
- Simple sensor alarm
- Minimize noise and ripple using low-noise buck converters
- How should the inductor of the switching power supply be placed correctly in PCB design?
- Which power supplies should be chosen for collection?
- Set timing circuit when power is on
- Power phase sequence display circuit
- Automatically set timer
- AD596-597 functional diagram
- Power circuit a composed of intelligent thyristor modules
- Floating input circuit (9V power supply)
- Single-ended input circuit (5V power supply)
