CS7232 touch stepless dimming light circuit (2)
Source: InternetPublisher:newlandmark Keywords: Stepless dimming touch type dimming lamp Updated: 2020/12/22
On the basis of the above example, r-photometering circuits are added, which can be used to transform an ordinary desk lamp into a
special high-blocking eight-light desk lamp for eyesight protection and writing.
= One-pole tubes VT2 and VT.3 form a Schmitt circuit, and the photoresistor RL (
the ordinary MC45 type photoresistor with a high resistance less than Skn and Anyangdagan 1Mfl and other series photoresistors) is used to feel the tflfi surface, that is, the writing surface. The light
shines on the cliff. When the light eagle calls normally (JOlx), RI shows low resistance, causing VT2 to be turned on, VT3
to be turned off, and the light-emitting symbol T FD is small and bright; if the light illumination is too weak, less than iooix, RI is trapped. The value becomes larger,
the Schmitt trigger flips, wr2 is cut off, VT3 is turned on, and the luminous tube IFD lights up and alarms. Students can touch
M to adjust the light, so that the illumination of the J2 operating surface increases until the LED goes out. Fine-tune RP, Changing the base
level of VT2 can adjust the alarm starting point of the photometric circuit .
- DIY a hat with a programmable LED display
- Circuit diagram of game score display using 7-segment LED
- Blinking LED circuit diagram based on LDR and resistor
- Solar battery and charging circuit
- Simple electronic doorbell circuit
- Gas flameout alarm circuit
- Lighting sound-activated switch circuit using thyristors Part 3
- Microwave Doppler warning circuit
- Chandelier brightness controller circuit using thyristor
- Photoelectric adjustment circuit
- Touch type alarm circuit 4
- One of the touch lighting switch circuits
- SS0619 touch step dimming light circuit
- Non-touch touch delay light circuit
- Touch delay lamp circuit using time base circuit (1)
- Touch delay light switch circuit (6)
- Use CD4069 to make touch delay energy-saving lamps
- Use CD4011 and CD4017 to make a touch-type five-speed dimmer
- Bidirectional thyristor stepless dimmer with light stabilizing function
- Use LS7232 to create a touch-sensitive dimming light
