Delay lamp circuit using bidirectional thyristor (3)
Source: InternetPublisher:抄写员 Keywords: Triac trigger Updated: 2021/11/22
It is a delay lamp circuit used with single-junction transistors. Normally, the thyristors VI and H are turned off, and
the light does not light up. When turning on the light, just press SB, and the light F will light up. When the light is off, the 220V AC power is stepped down by T, rectified by VD1 and VD2, and then provides the door panel triggering current
to VTH through the resistor R. When VTH is turned on,
the button SB will be self-locked. , the lamp can continue to
shine. Then, the full-wave DC power is filtered by VD3
and capacitor c^, and passes through RP to C.
Charge. When the voltage across G rises
to the conduction peak voltage of single-junction transistor vu, vU
is turned on, and VTH is trapped and loses the trigger current. When
the alternating current crosses zero, it is turned off and the lamp E goes out.
Adjusting RP can change the delay time of the circuit .
VD3 plays an isolation role. If VD3 is cancelled,
when VTH is turned off, the trigger current can be fed to VTH through R due to C, so that the gate tube cannot be
turned off. T-cho uses a 220V/9V×2, 3VA small power transformer, and there are no special requirements for other components
- How to choose the right level of integration to meet motor design requirements?
- Car ice warning circuit sharing
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- DIY an electromagnetic levitation device
- An automated model railroad layout project using a microcontroller
- Design and principle analysis of practical electric curtain remote control device
- Magnetic door and window anti-theft alarm
- Homemade short circuit alarm device
- Night dog barking anti-theft reminder circuit
- Homemade anti-theft watchdog
- Electric plow control circuit
- Egg heating control circuit
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- Micro remote control receiving and control circuit
- Water dispenser double sheet control circuit
- Traffic traffic light control circuit
- Bidirectional thyristor motor drive circuit a
- Automatic dimming circuit using bidirectional thyristor
- CMOS to Triac Interface Circuit
- Triac single-phase control circuit
