Making a flashing light controller using LM567
Source: InternetPublisher:newrudeman Keywords: controller flashing light LM567 electric light Updated: 2021/08/28
Cl, VDI, VD2, and C2 form a simple capacitor step-down rectifier and voltage stabilizing circuit + output about 8v DC voltage to power the LM567
. Resistors R3, RP and capacitor C3 connected to the 5th and 6th pins of the integrated block form an
ultra-low frequency oscillator with a frequency of II/(R3 + RP) C3. This oscillation signal is directly output from pin 5 and added to the output via R2. The gate of the silicon-controlled VS
turns the VS gap on and off, so the lamp H can flash and emit light. By adjusting the resistance of the potentiometer RP, the flashing frequency of the lamp H can be adjusted
- Use MC1455PIG to make automatic cycle light-emitting diode circuit
- Solar battery and charging circuit
- "OR" logic element configuration circuit
- One of the bead-type emergency light circuits
- Gas flameout alarm circuit
- Lighting sound-activated switch circuit using thyristors Part 3
- Desk lamp dimming soft switch circuit
- Automotive LED driver circuit diagram using LT3486
- 6-digit cathode fluorescent triode display circuit
- Reverse polarity drive circuit
- TI TCAN4550 system basic chip analysis
- 26kW AC three-speed cargo crane control circuit
- Diode dimming circuit
- Touch type fade-out delay light circuit
- Touch delay light switch circuit (6)
- Touch delay light switch circuit (3)
- Use CD4069 and CD4017 to make a novel light flashing controller
- CJM03 composed of fuse scrap emergency controller
- FCOG6100 two-speed motor (or generator) controller
- Electric fan multi-purpose controller
