Make strobe light with NE555
Source: InternetPublisher:张七岁 Keywords: NE555 BSP rectifier oscillation circuit Updated: 2021/01/30
The strobe light circuit made with NE555 is shown in Figure 3-16. It consists of three major parts: power circuit, oscillation circuit , and flash circuit
. The 220V alternating current is rectified
by VDI and directly charges the capacitor C3. The resistor Rl has
the dual functions of limiting the current and preventing the glow discharge of the flash tube. The other channel of 220V AC power outputs about 12V stable DC voltage through c5 step-down current limiting, VD2, VD3 rectification and voltage stabilization and cl filtering
for power consumption of the oscillation circuit . The NE555 time base circuit forms a self-excited multivibrator, and pin 3 outputs square wave pulses. After power is turned on, the indicator LED2 can be seen
flashing one after another. If the switch SB is pressed, the contact kl of the relay K will suck and release. When kl absorbs the stage,
the charge stored in C4 is rapidly discharged through the primary of transformer T, and its secondary coil induces a high voltage of tens of thousands of volts, triggering
the flash tube H to emit a strong flash. When the contact is disconnected, C3 replenishes energy for C4 through R7 and R8. Therefore, if you hold down SB
, the lamp H will emit bursts of flash continuously. Adjust the potentiometer RP, the flash frequency can be changed between 1 ~ 10Hz
- Build a Bluetooth-controlled wireless scoreboard
- Example of LED AC drive circuit
- Lighting lamp voltage stabilizing circuit (2)
- Transistor storage time test circuit
- Gas flameout alarm circuit
- Simple light-controlled street light circuit (7)
- Digital display multi-function thermometer circuit
- Fluorescent lamp electronic ballast circuit 11
- Fluorescent lamp dimming circuit composed of thyristors
- Simple sensor alarm
- Egg warming circuit
- Peanut and melon seeds roasting machine circuit
- Chicken supplementary light to increase egg production rate circuit
- Biogas concentration detection line
- Frequency modulator composed of NE566
- Varactor Diode Frequency Modulator
- base amplitude modulation circuit
- Schiller oscillator circuit
- superheterodyne radio circuit
- Guest arrival signal recognition circuit
