Use NE555 to make a single-button touch light switch
Source: InternetPublisher:抄写员 Keywords: touch switch NE555 BSP Updated: 2021/11/13
The circuit for making a single- touch light switch using NE555 is shown in Figure 3-4. This circuit is very similar to the circuit introduced in the previous section
. Its power rectifier part is exactly the same, that is, no matter whether the thyristor VS is in the on state or the blocking state,
both ends of can stably output 6V DC voltage to provide the time base. Circuit A uses electricity. Just change the touch electrode piece from the original two pieces into one
piece, connect the trigger end pin 2 of the time base circuit to the value breaking end pin 6, and then connect it to the touch electrode piece M through the high resistance resistor R4
When the circuit is first powered on, the state of the time base circuit is random. Assume that the initial state is the reset state, pin 3 outputs low level,
vs is in the blocking state, and the light H does not light up. When you need to turn on the light, just touch the electrode piece M, and the clutter signal induced by the human body is simultaneously
added to pins 2 and 6 of the time base circuit through R4. The positive half-cycle signal has no effect on pins 2 and 6 at this time, and The negative half-cycle signal
can trigger pin 2, causing the circuit to quickly flip and set, and pin 3 will output a high level. VS will get the trigger current and turn on, and the lamp H will
light up, and the circuit can always maintain this state. When you need to turn off the light, you still touch the electrode piece M. The same clutter signal
induced is added to pins 2 and 6 of the time base circuit at the same time. However, at this time, the negative half cycle of the signal affects both pins 2 and 6. It does not
work, and the positive half-cycle signal can trigger the threshold terminal of pin 6, the circuit quickly flips and resets, pin 3 outputs low level, vs
loses the trigger voltage, when the alternating current crosses zero, it turns off, the lamp H goes out, and The circuit can always maintain this state.
From the above analysis, it can be seen that every time a human hand touches the electrode sheet M, the state of the circuit changes once, that is to say, if you touch it
once, the light will be on: if you touch it again, the light will be off. The nozzle is very convenient to use. But you need to pay attention when using it. When turning on and off the light, just
touch M with your hand. Do not hold M for a long time. If you hold it down for a long time without letting go, the light H will
flicker and jitter.
- Making a photometer with light measuring function
- Audio level LED and digital dual display circuit
- IRS2530D electronic ballast circuit diagram
- Use NE555 to make a lighting and sound changing circuit
- Practical sensitive light-controlled switch circuit diagram
- Low illumination amplifier circuit
- Power outage emergency lighting
- Application circuit of CAT3606
- Large light emitting diode display circuit
- Bedside lamp controller circuit
- Motor forward and reverse control wiring diagram (2)
- Self-defense anti-riot circuit
- Fish pond oxygenation reminder circuit
- Rural fish farming control circuit
- Rural vegetable greenhouse lighting circuit
- Soil water shortage prompt circuit
- Junction field effect transistor mixer circuit
- base amplitude modulation circuit
- Schiller oscillator circuit
- Double gate field effect transistor high frequency amplifier circuit
