Single switch multi-light control circuit (3)
Source: InternetPublisher:张三叔 Keywords: switch control circuit BSP Updated: 2020/03/01
It is a multi-light circuit controlled by a single button SB. It selects a group or array of
light bulbs by pressing the number of times. There are 7 states to choose from. This circuit is suitable for controlling large chandeliers in the living room.
In the figure, VD1,vs,G,G,R. With R, it forms a simple lu-capacitance step-down half-wave rectifier and voltage stabilizing circuit.
After power on, it can output a DC voltage of about I?V to power the entire circuit. CD1518 is a dual 2/10 system counter
. This circuit only uses one of the counters. Each time SB is pressed, that is, the M① pin inputs a positive pulse signal
, and its input terminals ⑥, ⑤, ④, and ③ will output according to the OO01-1000 timing sequence of = u: among them, ⑤, ④, and
③ pins pass R s ~R. . Trigger the thyristors VTH1, VTH2 and VTH3 respectively to control
the lighting of the three groups of bulbs Il - F3. Pin ⑦ is the reset terminal. When pin ⑥ outputs "卣" level, the circuit can be reset.
The outputs of pins ③, ④, ⑤, and ⑥ are all ".", and the E1~F3 lights are all off. In this way, except for the reset situation, the ⑧-bit binary has a total
of 7 combinations of 2J -1, that is, there are 7 combinations of the light bulb lighting state. R and c are the initial power-on reset network,
which ensures that when the circuit is powered off and then powered on, the circuit is in the reset light and all lights are off. R, R: and C can increase
the stability of the circuit
C, Yaochuan CRB-400V type polypropylene capacitor. VTHl-VTH3 can use MAC94A4 small
plastic-encapsulated bidirectional thyristor. 1,1-.E3 The maximum power of each group of bulbs should not exceed 15DW. Other component parameters are shown in the
figure, there are no special requirements.
- Making a photometer with light measuring function
- LED acceleration and deceleration motion display composed of CD4017
- Low cost LED automatic emergency light circuit
- Design and production of rain control and light control timing controller based on P87LPC764
- Design and production of a practical electronic counting device
- Resistor value selection circuit
- Simple light-controlled street light circuit (7)
- One of the circuits that control one light in multiple placesb
- Remote anti-theft alarm
- Fluorescent lamp dimming circuit composed of thyristors
- electromagnetic field sensor
- Voice controlled flash LED light circuit diagram
- Analysis of rectifier circuit types and principles
- Farmland drainage automatic control circuit
- AC voltmeter
- Crabo oscillator circuit
- Capacitive feedback oscillator circuit
- High and low frequency signal generator circuit
- Color display circuit
- Digital stopwatch display circuit
