Digital stopwatch display circuit
Source: InternetPublisher:念慈菴 Keywords: Display circuit digital stopwatch BSP 5G Updated: 2020/01/22
The digital stopwatch circuit is shown in the figure. The 5G 5544 (ICl) in the picture is a quartz clock integrated circuit, used as a second signal generator in the circuit
. 5G5544
outputs pulses with a period of 2s from pins ③ and ⑤ .
After passing through the non-logical level conversion circuit
composed of VD3, VD4 and VT1 , the second
signal output can be obtained. CD4518 (102)
has two identical decimal
counters packaged inside, so it can form a two-digit count.
If more bits of counting are needed,
multi-level cascading can be performed.
CD4511 (IC3, IC4) is a
BCD-7-segment decoding/driver integrated circuit.
It decodes the BCD code output by the decimal counter
into a stroke code and drives the LED digital
display to display the counted seconds. As the seconds
signal continues to be added, the common cathode LED
digital display will continue to display the counting
number.
Sl is the clear switch, when Sl is pressed. The Cr terminal of CD4 518 can get a positive pulse to clear the circuit. Because the working voltage of the 5G 5544 integrated
circuit is 1. 2 ~ 2V, it needs to be provided with working power after being stepped down by VD1 and VD2.
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- How are diodes made using semiconductors?
- An article explains the working principle of the Wheatstone bridge
- How do Zener diodes protect circuits?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- DIY a decorative lamp
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- What is the difference between JFET and MOSFET
- Recommendations for 5G small base station power supply design
- Dual-channel 44 GHz vector signal generator, did you know?
- Have you heard of the new generation of handheld microwave analyzers?
- Egg warming circuit
- Peanut and melon seeds roasting machine circuit
- Crop anti-frost circuit
- Chicken supplementary light to increase egg production rate circuit
- Farmland irrigation automatic control circuit a
- Diode Balanced Mixer Circuit
- 5G14 current expansion circuit
