Brushless DC motor circuit
Source: InternetPublisher:风向西瓜 Keywords: DC motor electromechanical LED Updated: 2020/03/28
The working principle of the circuit : the rotor is a permanent magnet and the stator is four sets of coils. The four sets of
coils are respectively supplied with pulse signals controlled by the rotor, forming a rotating magnetic field to make
the rotor run. BC, the feeling comes from LED . The light signal to control lC. , BC3, so that they
are turned on and off (or turned off, saturated and turned on) respectively, so that the phase difference between L1 and L2 is
1800. In the same way, L3 and L4. The phase difference is 180°. The changing phases of the light signals from LED2 and LED 1
are 45° out of phase. Set four groups of coils as shown in the figure to form a
rotating magnetic field controlled by the rotor (no dead center).
- Analysis of the working principle of the sound and light controlled delay switch circuit
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Use your smartphone to turn on/off the power in your home
- Tutorial for building a remote-controlled Arduino Air-Boat
- An automated model railroad layout project using a microcontroller
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Hydraulic control circuit design and analysis
- Design and analysis of voice control circuit
- Design and manufacture of three-phase motor protection circuit
- PIC microcontroller controlled remote anti-theft alarm circuit
- LT3755 driver LED application circuit diagram
- Ordinary optocoupler isolation circuit
- A simple DC LED driver circuit
- 5-point LED driver circuit diagram of HA7666P/TA7667P
- Five-digit LED display audio power indication circuit diagram made with FD502
- Constant temperature measurement circuit
- IS0100 functional schematic diagram
- Paper thickness measurement circuit
- Basic structure of light-emitting diode (LED) display drive circuit
