20W power tube/tube amplifier circuit diagram with EL34
Source: InternetPublisher:风向西瓜 Keywords: Amplifier circuit electronic tube Updated: 2023/12/25
The picture below is a 20W power amplifier circuit diagram based on the electronic tube component EL34. EL34 is a very famous tube and is very suitable for power tube amplifiers.
The above circuit is a complete circuit, including the tube amplifier circuit diagram and the power supply circuit diagram. To make a stereo channel amplifier, just build a similar amplifier circuit and connect it to the power supply in parallel with another identical amplifier.
The EL34 tube is a power pentode type thermionic valve or vacuum tube. It has an international octal base (indicated by "3" in the part number) and is primarily used in the final output stage of audio amplification circuits and is designed to be suitable as a series regulator due to its high allowable voltage between heaters and Cathode and other parameters. The US RETMA pipe designation number for this pipe is 6CA7. The Russian analogue is 6P27S (Cyrillic: 6?27C).
The tube EL34 was widely used in high-power audio amplifiers of the 1960s and 1970s, such as the very popular Dynaco Stereo 70 and the Leak TL25 (mono) and Stereo 60, and was also widely used in high-end guitar amplifiers because of its incomparability with other octals. It is characterized by greater distortion at lower powers (considered ideal in this application) compared to tubes [citation needed] (such as 6L6, KT88, or 6550).
- TDA2009A power amplifier circuit
- Using TDA2822 to do direct coupler output experiment
- DIY 50W Gallstone Amplifier
- 18-inch large speaker
- Design and production of NE5532+TDA1521 amplifier
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- 6BX7 10W bile duct amplifier
- Stereo phono amplifier circuit with bass control composed of LM1877
- Dual power supply audio power amplifier circuit composed of LM4730/LM4731
- American Grado RA1 headphone amplifier
- Tube crossover balanced inverter circuit diagram
- Tube audio power amplifier circuit
- Dynamically biased high-fidelity power amplifier circuit (a)
- Diamond Differential BTL Power Amplifier Circuit-Power Amplifier
- Class A and B DC power amplifier circuit
- Power amplifier circuit using field effect transistor as output
- Fully symmetrical power amplifier circuit
- Power amplifier with simple and supreme sound quality 02
- Making LM1875 DC negative feedback BTL power amplifier circuit
- MC1306P audio power amplifier circuit
