Fluorescent lamp electronic ignition circuit
Source: InternetPublisher:JFET Keywords: fluorescent lamp Updated: 2020/09/06
The electronic ignition circuit of the fluorescent lamp is shown in Figure 1-58.
The diodes VDI and VD2 in the circle and the capacitors CI and C2 form
a double voltage rectifier. After the power switch S is turned on, a
pulsating DC current with a maximum peak voltage of about 600V can be generated at both ends of the capacitor C2
, thus causing the fluorescent tube H to start quickly. When the lamp
is ignited, the resistor R acts as a voltage reduction and current limiting function, allowing the lamp
to emit light normally at a suitable current.
- Digital level display (CD40147, CD4511)
- DIY a hat with a programmable LED display
- Power outage emergency lighting
- Simple electronic doorbell circuit
- Gift lamp music box circuit
- Motor speed photoelectric control circuit
- WT8089 holiday lights ASIC
- Three-way music lantern circuit
- Fluorescent lamp electronic ballast circuit 11
- Reverse polarity drive circuit
- Stepless dimming fluorescent lamp circuit
- EFS3A, EFS31 fluorescent lamp special integrated circuit
- Inverter circuit principle for lighting 6~12W fluorescent lamps
- Multifunctional emergency fluorescent light circuit
- Electronic rapid starter for fluorescent lamps
- Low cost fluorescent lamp electronic ballast circuit
- Fluorescent lamp automatic dimming circuit
- Double fluorescent lamp wiring method
- Fluorescent lamp energy-saving electronic ballast circuit 1
