Power outage emergency lights (2)
Source: InternetPublisher:司马缸砸光 Keywords: Emergency lights LED thyristor Updated: 2020/12/26
The switch S in the figure is usually in a closed state. The 220V AC power is stepped down by the transformer, rectified by the diode VD and
filtered by the capacitor C, and the DC working voltage is output for use by the transistor circuit. Due to the biasing effect of resistor R3. VT is in a saturated
conduction state, and its collector, that is, the gate of the silicon-controlled vs is at a low level, so vs is in an off state and the lamp H does not light up. At this time,
the light-emitting diode LED lights up, indicating that the mains power supply is normal. Once the mains power suddenly fails, due to the small capacity of the filter capacitor C,
the transistor VT is immediately cut off, thereby releasing the blockade of the thyristor vs. The gate of vs can obtain a forward
trigger current through the resistor
R4, vs is immediately turned on, and the light H stands for luminous lighting. At this time, the light-emitting diode LED indicating normal power supply from the mains also
goes out.
- Build a Bluetooth-controlled wireless scoreboard
- IRS2530D electronic ballast circuit diagram
- Low cost LED automatic emergency light circuit
- battery charging circuit
- Low illumination amplifier circuit
- Simple light-controlled street light circuit (7)
- WT8089 holiday lights ASIC
- Gas and smoke alarm circuits with intermittent alarms
- Three-way music lantern circuit
- Temperature control alarm circuit
- Analysis of various forms of packaging structures of LED light-emitting diodes
- Teach you a thyristor dimming LED drive power circuit design
- MAX684 charge pump driving white LED circuit diagram
- Practical circuit diagram of an LED lamp cup
- LED backlight driver module design circuit
- PWM brightness adjustment circuit diagram
- Simple light-emitting display logic pen circuit
- Three-phase alternating current detection circuit
- Industrial static elimination circuit
