LED backlight driver module design circuit
Source: InternetPublisher:ghaytweyhtoo Keywords: LED diode power display power supply Updated: 2021/12/06
![LED backlight driver module design circuit](http://www.eeworld.com.cn/circuit/upload/5fbf55dd83cec511f64e5a97df2aed6b/634191360eef871784e3a3ac612df49e.jpg)
Circuit analysis: The requirement of the backlight driver is that the brightness of the backlight LED remains unchanged under any conditions, that is, a constant current source circuit needs to be constructed. The backlight drive circuit shown in the figure is the simplest constant current source circuit. When the circuit is working, the voltage across resistor R9 is equal to VLL1 plus the BE conduction voltage, which is a fixed voltage of about 1.7V. The current flowing through R9 is also fixed. The current is approximately equal to the emitter current and collector current of Q2, so the current flowing through the backlight diode D1 is also a constant current, realizing the constant current drive of the backlight LED. The driving current of the backlight LED is about 10mA, and the value of R9 is 150Ω.
- Analysis of the working principle of switching regulator
- Practical and convenient fax machine power supply control circuit
- Op amp power supply decoupling bypass measures
- Driving circuit that controls LED brightness using PWM signal
- Dynamic power supply for power amplifier controlled by thyristor
- Power supply circuit that can reduce LM317 ripple
- Car power 1.5V-12V six-speed converter
- 0.7~24V continuously adjustable current limiting power supply
- Design of electric vehicle charger
- LM317T voltage regulation adjustable circuit diagram explanation
- What sensors does the phone have?
- Op amp driving LEDs
- LED backlight driver module design circuit
- heartbeat sensor
- High battery life LED circuit based on GEC8310
- Working principle of single touch mode light switch
- 3W high power LED drive circuit diagram
- LED level meter driver integrated circuit diagram
- Power outage sound and light alarm circuit
- 4 and 1/2 LED digital display (DMS-40PC series)
