Light-controlled lighting with triac (1)
Source: InternetPublisher:他们逼我做卧底 Keywords: Triac light controlled lighting LED Updated: 2021/06/21
Similar to the circuit introduced in the previous section, the photoresistor RG and the fixed
resistor Rl also form a voltage divider. The light-emitting diodes
LED 1 and LED 2 here also serve as power indicators and rectifier
triggers. When the alternating current is in the upper and lower positive half cycle, LED2
is turned on (of course at night) to provide a positive trigger current to vs.
When the alternating current is in the upper and lower negative half cycle, LED1 is turned on (it should
also be at night ) provides reverse trigger current to vs. During the day,
the indoor natural light is strong. RG has low resistance and low partial voltage value, vs cannot be turned on and the light H does not light up. Only
when night falls, the partial voltage value is higher. This AC voltage is added to the control electrode of the thyristor vs through LED1 and LED
2, so that vs is turned on, and the lamp
H lights up normally. RP can be used to adjust the sensitivity of the light control.
- TEC laser diode driver circuit
- A white light LED power outage emergency light
- IR2153 emergency fluorescent lamp circuit diagram
- Design and production of digital number answering machine
- battery charging circuit
- Lighting lamp voltage stabilizing circuit (2)
- 4-digit incandescent lamp display circuit
- Motor speed photoelectric control circuit
- AC and DC dual-purpose flash light
- Electronic music dimming desk lamp circuit
- What sensors does the phone have?
- MAX684 charge pump driving white LED circuit diagram
- NE555 typical application circuit diagram (2)
- LED lighting display detection circuit with overload protection
- 3W high power LED drive circuit diagram
- SAA1064 serial I2C bus LED dynamic driver interface circuit diagram
- Five-digit LED level indication driver integrated circuit typical circuit
- Soil moisture detection circuit
- Power outage sound and light alarm circuit
- Digital camera flash control circuit
