Power outage sound and light alarm circuit
Source: InternetPublisher:newlandmark Keywords: Alarm circuit LED BSP oscillator Updated: 2021/05/18
The power outage sound and light alarm circuit is as shown in the figure. The circuit consists of AC detection (left half) and audio oscillator (right half).
The AC 220V is rectified by VD and filtered by C1 to obtain 300V DC high voltage. One DC path passes through Ri to make the light-emitting diode LED 1 emit light, and the other
path passes through Rz and is sent to the ① pin of the optical coupler 4N25, causing the internal LED to light up. The light shines on the phototransistor, and the phototransistor shows low current
The resistor is turned on, pulling the base potential of VT1 to the ground potential, and the audio oscillator cannot work normally. There is no current flowing through the speaker and the light-emitting tube, and they neither sound
nor emit light.
Once there is a sudden power outage, the detection voltage at both ends of c] disappears, LED1 goes out, and the internal light-emitting tube in the optocoupler also goes out.
The phototransistor is not exposed to light and shows high resistance, and the base of VT1 is no longer short-circuited by the optocoupler. arrived. The audio oscillator composed of VT1, VT2 and other components meets
the oscillation conditions and starts to oscillate, making the speaker and LED2 sound and light up. When the mains power is restored, LED I lights up.
- IR2153 emergency fluorescent lamp circuit diagram
- Practical sensitive light-controlled switch circuit diagram
- Low illumination amplifier circuit
- Lighting lamp voltage stabilizing circuit (2)
- 4-digit incandescent lamp display circuit
- Desk lamp dimming soft switch circuit
- Electronic music dimming desk lamp circuit
- Fluorescent lamp electronic ballast circuit 11
- Fluorescent lamp dimming circuit composed of thyristors
- Mains undervoltage and overvoltage alarm circuit 2
- Motor overcurrent protection circuit
- Electronic thermometer circuit
- Ultrasonic blind pathfinder circuit
- Rice mill circuit
- Poultry warming temperature control circuit
- Farmland irrigation automatic control circuit b
- DC ammeter
- Parallel crystal oscillator
- Voltage controlled power supply second-order high-pass filter circuit
- Motorcycle flash light circuit
