Bidirectional thyristor stepless dimmer
Source: InternetPublisher:无人共我 Keywords: Triac stepless dimming dimmer Updated: 2021/10/03
When turning on the light, close the switch S, and the 220V alternating current charges the capacitor C2 through RP1, RP2 and R. When the voltage
at both ends of C2
reaches the turning voltage of the bidirectional trigger diode VD, VD and the triac VS conduct one after another, causing the controlled lighting Lamp H
gets electricity and shines. When the alternating current crosses zero and reverses direction, vs turns off itself, C2 begins to reverse charge again, and the above process is repeated. It can be seen that
in each cycle of alternating current, vs is symmetrically conducted once in the positive and negative half cycles. If the resistance value of RPI is adjusted,
the charging rate of capacitor C2 will be changed, thereby causing the vs trigger conduction time to move forward or backward in any half cycle, that is,
the vs conduction angle is changed, and the corresponding voltage applied to both ends of the lamp H is changed. The average voltage also changes accordingly, so the purpose of stepless dimming can be achieved.
- Example of LED AC drive circuit
- Audio level LED and digital dual display circuit
- LED acceleration and deceleration motion display composed of CD4017
- DIY a hat with a programmable LED display
- IR2153 emergency fluorescent lamp circuit diagram
- battery charging circuit
- Low illumination amplifier circuit
- Two-way electronic music doorbell circuit
- Fluorescent lamp electronic ballast circuit 11
- SH-803R holiday lights ASIC
- Bidirectional thyristor stepless dimmer with light stabilizing function
- Triac two-tone dimmer (2)
- Stepless dimming lamp circuit using application-specific integrated circuit
- Triac protection circuit
- Arc suppression circuit using bidirectional thyristor
- 800W lamp dimmer circuit diagram
- Novel and simple dimmer circuit
- Simple hybrid dimmer circuit
- 800w dimmer circuit
- Baby room automatic dimmer circuit
