Incandescent lamp life extension electronic controller (2)
Source: InternetPublisher:通通 Keywords: electronic controller incandescent lamp Updated: 2021/07/06
The high-power field effect transistor VT, resistors Rl and R2, and capacitor C form a circuit that limits the starting current . Since VT must
operate normally under direct current, a bridge rectifier circuit is composed of diodes VD1-VD4, which
converts 220V AC power into DC pulsating voltage , which is then used for VT work. Close switch S. Since the voltage across the capacitor C is zero and cannot change suddenly,
VT is in a cut-off state and the lamp H cannot light up immediately. over time. C is gradually charged to voltage through Rl
, and VT also changes from the cut-off state to the saturated state through the amplification area. The current of its drain D gradually increases from zero to the
rated , thus avoiding the moment when the light is turned on. The cold resistance of the filament is very small, which causes a strong current to impact the filament, causing the power supply
voltage to slowly increase to both ends of the bulb as the filament temperature gradually increases.
- Build a Bluetooth-controlled wireless scoreboard
- LED acceleration and deceleration motion display composed of CD4017
- USB powered portable light
- LED Signage with RS232 Port Operation Guide
- Lighting lamp voltage stabilizing circuit (2)
- Simple electronic doorbell circuit
- Incandescent lamp dimming circuit using thyristor part 4a
- SH-803R holiday lights ASIC
- Bedside lamp controller circuit
- Night target display circuit diagram
- One light one switch lighting circuit
- One of the incandescent lamp dimming circuits using thyristors a
- Incandescent lamp life extension circuit 5
- Incandescent lamp life extension electronic controller (1)
- Incandescent lamp life extension switch circuit (1)
- 4-digit incandescent lamp display circuit
- Cold storage incandescent lamp voltage delay switch circuit
- Incandescent light bulb flasher
