Electric blanket cycle timer circuit
Source: InternetPublisher:三岁就很酷 Keywords: timer circuit electric blanket switch NE555 Updated: 2021/03/22
Circuit working principle: When the circuit is connected to the mains power, R. , C, resistor-capacitor current limiting buck
, VD. One VD4 rectifies and C2 filters to obtain +12 V DC, which
supplies power to Ic, and relay K. The switch S on pin 4 of Ic is a single-pole single-throw switch , which is not turned on at ordinary times.
According to the NE555 circuit principle, the NE555 circuit does not work when pin 4 is not connected to high potential , that is,
pin 3 outputs low level, K pulls in, and K . . , closed, the electric blanket is heated electrically. At this time, the delay
on/off circuit does not work. Only when the person is sleeping and feels that the temperature of the electric blanket
meets the needs, S will be closed, and the circuit will automatically delay on/off. The power-on time
is determined by R4, C3, Rs, RP, VDs, etc., and the range can be set from 5min to th. The shutdown
time is determined by R4, VDs, RP2, and C3, and the range can be set from 5 minutes to th.
- How to use a microcontroller to control a servo motor?
- Use your smartphone to turn on/off the power in your home
- Peripheral circuit of automotive motor controller power supply chip
- Introduction to the internal structure of the Delta winding motor
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Design and analysis of wire control circuit
- Design and production of wireless multi-location control switch circuit
- Precious home appliance anti-theft alarm
- Password type motorcycle anti-theft device
- NE555PWM pulse width modulation circuit
- NE555 exponential voltage controlled oscillator circuit diagram
- Use NE555 to make light-controlled automatic lights
- Time sharing timer circuit
- Pocket LED reading light circuit composed of NE555
- Clever use of NE555 as a cycle timer circuit with adjustable on-off time
- Clever use of NE555 as long timer circuit diagram
- Fast charger circuit diagram using NE555
- Constant current timing charger circuit diagram using NE555
- DC voltage polarity converter circuit diagram composed of NE555
