Voice controlled electric curtain machine circuit
Source: InternetPublisher:ghaytweyhtoo Keywords: Electromechanical voice control electric curtains Updated: 2021/02/12
Circuit working principle: The circuit is mainly
composed of microphone MIC, voice control trigger circuit IC2, motor drive circuit and DC reversible motor. Microphone MIC is
an acoustic-to-electrical conversion element, which converts acoustic signals into electrical signals to control
the output state of the IC2 trigger circuit. The trigger sensitivity can be selected from three options through the peripheral circuit of IC2. IC2
is a special voice control circuit . It has 14 pins and two packaging forms. aa is for
power supply decoupling. If no capacitor is added during use, aa should be connected together. The chip is internally
composed of amplification, delay, rectification, frequency selection, triggering and driving. The output has three
states: when a control signal is received, the output state changes once. Therefore, when the controlled
actuator is a motor, the motor status can be changed to forward rotation, stop, reverse
rotation, and stop in sequence.
- Detailed explanation of the working principle of the parking light circuit
- Hot wire spark plug control circuit
- Design of hydroponic farm based on IoT
- UCC587x-Q1 power-on false alarm mechanism and initialization precautions
- One control three constant pressure water supply frequency conversion speed control circuit a
- Vehicle electronic fuel gauge circuit
- Nine-digit key code lock circuit
- Smart transmitter circuit diagram with hart interface
- Small improved circuit of hanging electronic watch
- Sensor alarm circuit
- Voice-activated recording circuit (2)
- Manual and voice-controlled delayed lights-off switch circuit
- Voice controlled delay lights out switch circuit
- Beautiful voice controlled music doll circuit
- Voice controlled backup lighting circuit
- Fully automatic voice-activated strobe light circuit
- Voice controlled delayed farewell light circuit
- SK-I voice controlled motor switch circuit
