DC welding machine no-load automatic power-off circuit
Source: InternetPublisher:风向双子座 Keywords: Automatic power off DC welding machine AC contactor Updated: 2021/03/11
Circuit working principle: This device consists of signal power supply, transistor amplification and control circuit
. The capacitors C and C3 in the line are connected in parallel with the main contact of the AC contactor JC and in series with
the primary coil of the rectifier transformer ZB. When the switch K is closed, the normally closed
contact J of the time relay is energized and closed, and the AC contactor JC is energized and closed, making the welding machine temporarily charged. After the time
relay SJ passes with a delay of about 10 s, its normally closed contact is disconnected, the contactor JC coil
loses power, and the welding machine is in a power-off state.
- How to improve SiC traction inverter efficiency with real-time variable gate drive strength
- Method for converting a spark ignition system to an enhanced sequential spark ignition system for a 6-cylinder engine
- Audio Adapter Cable - Upgrading Car Audio with MP3 Player
- Homemade disinfectant circuit
- XDH-2 electrocardiograph circuit
- JC3.5 hydraulic controller and its wiring a
- Micro infrared receiver module PIC-12043S circuit diagram
- Enhanced password lock circuit using AE1169
- Catillac luggage compartment closing circuit diagram
- Stapler control circuit
- Electric sewing machine power saving circuit
- Yarn dyeing machine automatic control circuit b
- Yarn dyeing machine automatic control circuit a
- AC contactor interface circuit using bidirectional thyristor
- HG40 series thyristor capacitor switch wiring
- Transformer AC contactor DC operation circuit c
- Capacitive AC contactor DC operation circuit c
- Capacitive AC contactor DC operation circuit b
- DC motor forward and reverse control circuit b
- Water pump motor protection circuit
