DC motor forward and reverse control circuit b
Source: InternetPublisher:elleny Keywords: DC motor control circuit forward and reverse control AC contactor Updated: 2021/12/04
When SB2 is pressed in the control circuit, the coil of AC contactor KM1 is energized, the moving main contact KM1 of KM1 is connected, and the DC motor
M rotates forward; when SB3 is pressed, the coil of AC contactor KM2 is energized. The moving main contact KM2 of KM2 is turned on, the circuit is cross-connected,
the current flow direction in the armature circuit is changed, and the DC motor M is reversed. Interlocking is implemented in the circuit. When one branch is connected, the other branch is immediately cut off
. The RP can change the speed of the motor. As shown in Figure 4-25a. For forward and reverse rotation control of series-wound DC motors ,
- Use your smartphone to turn on/off the power in your home
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- How to make a wheeled self-balancing robot using ultrasonic sensors
- How to set up a cheap beam break sensor control distance scene using a reflector
- Perform surgery on the speaker protection circuit
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Night dog barking anti-theft reminder circuit
- Password type motorcycle anti-theft device
- "Watchdog" anti-theft alarm circuit
- Agricultural spraying and insecticide control circuit
- Flashing wall light control circuit
- Paper tension control circuit
- Car window control circuit
- Multi-pole leakage protector circuit a
- Automatic tuning control circuit
- Capacitive AC contactor DC operation circuit b
- 2△-Y-△ connection three-speed motor contactor control circuit
- DC motor forward and reverse control circuit b
- Emergency wiring of AC contactor lacking auxiliary contacts B
