HT7713 dimming control ASIC
Source: InternetPublisher:吃掉星星 Keywords: Application specific integrated circuit light control touch Updated: 2021/04/01
The typical application circuit of HT7713 is shown in Figure 2-12. In the figure, VDI, Rl, VD2 and C2 form a simple resistor
step-down half-wave rectifier and voltage stabilizing circuit, which outputs about 10V DC voltage for the integrated block. The AC synchronization signal is fed by resistor R2.
M is a touch electrode piece. When a human hand touches M, a control signal is input to the integrated block, and pin 3 outputs a trigger signal
to control the conduction angle of the thyristor vs. When M is touched for the first time, the lamp H emits weak light; when M is touched for the second time, the lamp emits medium light
; when M is touched for the third time, the lamp emits strong light; when M is touched for the fourth time, the lamp goes out; when M is touched for the fifth time, the lamp H emits weak light again. Light... follows this cycle
to select the brightness of the electric lamp. C4 is an isolation safety capacitor to protect users from electric shock. VD3 and VD4 are
protection diodes, which can prevent damage to the integrated block due to accidental input of excessive touch signals.
- Experiment on realizing photoelectric alarm using photosensitive devices
- Fire safety evacuation emergency signs
- Working Principle of CCFL and Analysis of Electronic Driving Circuit
- LED Flasher circuit using 2 transistors for LED switching
- Corridor automatic light-off device
- Gas flameout alarm circuit
- Colorimeter circuit
- Two-way electronic music doorbell circuit
- Automotive LED driver circuit diagram using LT3486
- Electronic rapid starter for fluorescent lamps
- Light controlled automatic curtain circuit
- Light controlled delay circuit (2)
- EFS3A, EFS31 fluorescent lamp special integrated circuit
- VH5162 Holiday Lights ASIC
- SH-804 Holiday Lights ASIC
- SH-803R holiday lights ASIC
- SE9201 Holiday ASIC
- ML81 then lantern ASIC
- PT2102 dimming control ASIC
- SM7232, CS7232 dimming control application specific integrated circuit
