The motor is equipped with a high-sensitivity comprehensive protection circuit
Source: InternetPublisher:酷到被通缉 Keywords: Protection circuit motor relay Updated: 2020/06/23
Working principle of the circuit: According to the actual situation that the winding will heat up first before the motor burns out, a small thermal relay
is installed on each phase winding of the motor , and the two
thermal relays are connected in series. As long as the winding temperature reaches the thermal relay Curie point temperature
(95℃), the thermal relay will automatically disconnect for protection.
The winding temperature of the motor during normal operation is much lower than the starting temperature of the thermal relay , so major electrical accidents can be avoided
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- How to Make a Simple Chicken Incubator
- Introduction to the internal structure of the Delta winding motor
- Squirrel cage asynchronous motor reverse braking control circuit
- Motor self-starting circuit
- Simple phase failure protection circuit composed of intermediate relay
- Design and analysis of wire control circuit
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Audio interface protection circuit
- An experimental model of an infrared radio alarm
- Motor overcurrent protection circuit
- Capacitive Neutral Leakage Protection Circuit
- Low voltage circuit breaker protection circuit a
- Motor waterproof protection circuit
- Asynchronous motor protection circuit composed of photoelectric coupler
- USB interface circuit of Newman MP4 machine
- Thyristor overcurrent protection circuit 5
- Mains undervoltage and overvoltage protection circuit 4
- Overcurrent protection circuit for generator low voltage start b
- Overcurrent protection circuit for generator low voltage starting a
