Water tower automatic water supply control circuit
Source: InternetPublisher:宋元浩 Keywords: Control circuit NE555 Updated: 2021/07/01
Working principle of the circuit: three metal sheets l, 2, and 3 are suspended in the water tank of the water tower using wires with insulators. When the water level in the water tower is below the metal sheet 2, the voltages of pins 2 and 6 of the time base circuit
NE555 are both 0 , it can be seen from the logic state of NE555 (see
attached table) that at this time pin 3 has a high level output, the transistor VT is saturated and turned on, the motor is powered to
pump water, and the water level in the water tank rises. When metal sheet 2 is submerged but has not yet reached metal sheet 3 , this is equivalent to a resistor
being connected between metal sheets 1 and 2. As can be seen from Figure 1-3,
this is equivalent to connecting pins 4 and 2 of the power supply. By adding a resistor, if the size of the metal piece
is appropriate, the potential of pin 2 of the time base circuit NE555 can be greater than 1/3 Vcc, but
the voltage of pin 6 is still 0 at this time. It can be seen from the logic state of the time base circuit that the output state of NE555
remains unchanged at this time, that is, the motor continues to pump water. When the water level touches the metal sheet 3, because the water conducts electricity, it is equivalent
to connecting a resistor
between pins 4 and 2, pins 4 and 6, and pins 2 and 6 of NE555 , so that pin 2 of NE555 The voltages of pin 6 and pin 6 are all greater than 2/3 Vcc,
so pin 3 of the output terminal outputs low level, the transistor is cut off, and the motor stops pumping water.
- A simple magnetic switch circuit sharing
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- How to choose the right level of integration to meet motor design requirements?
- How to remotely control devices using ESP8266 and LPC2148
- Tutorial for building a remote-controlled Arduino Air-Boat
- Introduction to the internal structure of the Delta winding motor
- Perform surgery on the speaker protection circuit
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Simple three-phase motor phase loss protection circuit
- A novel and practical power line anti-theft and cutting alarm circuit
- Multi-channel patrol detection control circuit b
- Photocell amplification control circuit
- multi-tone alarm
- Use NE555 to make automatic telephone lighting
- Overvoltage and overcurrent protection circuit diagram using NE555
- Nickel-cadmium battery fast charger circuit diagram using NE555
- Charger circuit diagram using NE555
- Circuit diagram of stable and adjustable negative output voltage composed of NE555
- Pulse width modulation switching regulated power supply circuit diagram composed of NE555
