multi-tone alarm
Source: InternetPublisher:spectrum Keywords: Speaker alarm NE555 555 circuit Updated: 2020/09/26
![multi-tone alarm](http://www.eeworld.com.cn/circuit/upload/560b9bbe804c85363e9e5c6970fcb635/fe8a068031942c20e53fcb9b0d352c00.gif)
multi-tone alarm
Shown is a multi-tone alarm. This circuit uses the NE555 time base circuit to form a multi-tone alarm , which can monitor points a, b, c, and d at the same time. Chou, the four points b, c, and d are connected to the ground wire with wires. The J detection lines can be set in different positions. When the four points a, b, c and d are all short-circuited to the ground, the NE 555 circuit stops vibrating and the speaker is silent. When an intruder breaks any of the protection lines, the potential of this point rises - the corresponding diode is turned on, the NE555 circuit starts to vibrate, and the speaker sounds an alarm. For different monitoring points, the circuit oscillates at different frequencies and the speaker tones are also different.
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Benefits of Wide Bandgap Technology for Power Converters
- Practical and convenient fax machine power supply control circuit
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Visible laser digital control modulation driver
- Simple and practical LED lamp driving circuit
- Current/voltage conversion circuit using current converter
- LM317 regulated power supply
- USB power socket using the car battery
- Mc34063 MP3 Switching Charger
- Oscillation frequency is about 22KHz field mosquito repellent circuit diagram
- Light control circuit diagram using 555 time base circuit
- Acousto-optic digital level detector circuit diagram
- Use NE555 to make a two-button touch light switch (1)
- NE555 flashing light circuit diagram
- Sound and light logic pen composed of NE555 circuit
- Control circuit using NE555 integrated circuit_2
- Overvoltage and overcurrent protection circuit diagram using NE555
- Constant current timing charger circuit diagram using NE555
- Bipolar DC and DC voltage stabilizing converter circuit diagram composed of NE555
