Simple electronic keyboard circuit
Source: InternetPublisher:3228 Keywords: electronic keyboard speakers Updated: 2021/10/25
Circuit working principle: Rp1~Rp13 are the scale resistors of the electronic keyboard and
the timing resistors of the oscillator, C2 is the wide discharge capacitor, and S1-S13 are the key switches. Press any one of S1
to S13, for example, press S1, then the +6 V power supply will charge to C2 through Rp1 and S1
. Because the voltage at C2 terminal is zero at the beginning of charging, VT1 cannot be turned on. At this time, the +6 V power
supply provides base bias for VT2 through R, VT2 is turned on, and the current flows through
the speaker through the c and e poles of VT2 , and a higher voltage drop occurs at both ends of the speaker .
- Audio Adapter Cable - Upgrading Car Audio with MP3 Player
- Binary clock design based on FPGA
- Four water tower control schematic diagram
- JC3.5 hydraulic controller and its wiring a
- Gantry milling machine spindle control circuit
- Music calendar using SMC6S37
- Enhanced password lock circuit using AE1169
- Catillac luggage compartment closing circuit diagram
- Electronically controlled fuel injector test circuit
- Nine-digit key code lock circuit
- multi-tone alarm
- Frequency divider circuit diagram
- Class S power amplifier 01
- Electronic keyboard stabilized power supply circuit with short circuit protection
- Pure DC current negative feedback power amplifier circuit made by LM3886TF
- Speaker power limiter circuit
- Button activated speakers
- Electronic keyboard circuit
- Hi-Fi loudspeaker 3-way and 4-way crossovers
- Toy electronic keyboard circuit
