Simple answering machine circuit
Source: InternetPublisher:奥特man123 Keywords: buzzer circuit register binary Updated: 2020/10/14
The working principle of the circuit: when a certain button is pressed, the binary digital code
is input into the 5-bit register IC 2 through the parallel input/output port , and then the parallel input port of the register is "locked" through the parallel enable terminal
(pin 8) of IC
2, so that No other data is allowed to be entered into the
register. Only after pressing the reset switch S can the stored numbers be deleted from the register
and other data can be received.
- How to design a health emergency alert device using MPU6050
- Digital display time relay circuit
- Homemade disinfectant circuit
- EKG FM Demodulator Circuit
- Teana A33-EL anti-theft alarm system circuit diagram and schematic diagram 7
- Wired centralized control circuit that directly starts the water pump motor
- Remote control fan speed regulator circuit
- G-6805 therapeutic instrument circuit
- Cadillac reversing light circuit diagram
- Simple temperature control circuit diagram
- Dual timing multiplexer circuit
- Refrigerator door opening alarm circuit
- Optocoupler digital display answering machine circuit-b
- Multifunctional intelligent answering machine circuit
- Six-way answering machine circuit-b
- BCD-Binary number conversion circuit diagram
- Binary addition and subtraction circuit
- Binary Parallel Addition and Subtraction Circuit
- Binary addition and subtraction circuit using arithmetic logic units
- 8-bit binary serial addition and subtraction circuit
