Dual timing multiplexer circuit
Source: InternetPublisher:王达业 Keywords: Multi-channel answering machine answering machine circuit LED Updated: 2020/09/16
Circuit working principle: The dotted box in the upper right corner of the figure represents
the operation box of each competition team. Now assume that the first group presses the answer button, AN01, and it is pressed.
The 7.8 V voltage passes through LED 2 and VD, causing VS01 to trigger conduction, causing H01, H1 and LED 01
to all light up. Since there is a voltage drop of about 4V across H1 and R1, HA1 rings immediately. In addition,
since the voltage at both ends of the IED2 and VD1 components is less than 4V at this time, it is impossible to
trigger other thyristors to conduct again.
- How to improve SiC traction inverter efficiency with real-time variable gate drive strength
- DIY a practical audio-visual doorbell
- Ways to deliver more than 100A to ADAS processors
- UCC587x-Q1 power-on false alarm mechanism and initialization precautions
- One control three constant pressure water supply frequency conversion speed control circuit a
- Vehicle electronic fuel gauge circuit
- Electric massager circuit
- Smoke alarm circuit (1)
- Analog counter circuit circuit diagram
- Cadillac reversing light circuit diagram
- MAX8631X driving white LED circuit diagram
- Circuit diagram of a high-brightness and energy-saving LED lamp cup
- LED backlight driver module design circuit
- heartbeat sensor
- LED lighting display detection circuit with overload protection
- LED signal amplification circuit diagram
- Electric blanket internal disconnection measurement circuit
- Power outage sound and light alarm circuit
- Coin guessing game circuit
- Light emitting diode (LED) display driver circuit
