Dimming light circuit using parametric solid state relay
Source: InternetPublisher:黄土马家 Keywords: solid state relay dimmer light voltage drop Updated: 2021/08/04
The stepless dimmer
lamp circuit using parametric solid-state relay is shown in Figure 48 (a). To understand
the working principle of this dimmer, you must first be familiar with
the working characteristics of parametric solid-state relay. The working characteristics of parameter comrade relays can be divided into positive power drive
, negative power drive and passive power drive according to the driving power. This circuit is a passive power drive. Under passive power
drive conditions, the relationship between the control terminals ①, ②, ③, and ④ pins and the output terminals ⑤ and @ pins is as follows; when
the input impedance of the control terminals ③ and ④ pins When z, (i.e. RI'] + RP2) is less than Lei, the impedance of the output terminals ⑤ and ⑥ is extremely
large, and the voltage drop (U,.) is close to 220V, that is, the parameter solid state relay PSSR is turned off, and the lamp E does not light up at this time. When
the input impedance z between @ and @ pins. . Greater than z. When , the impedance of the output terminals @ and ⑥ is extremely small, and the voltage drop (U.e) is close to
oV, that is, the PSSR is turned on, and the lamp E lights up normally at this time; when the input impedance between the control terminals ③ and ④ is Z,.
(That is, RPl + RP2) is between 厶 and 磊, and the pressure drop (U5e) of the output terminals ⑤ and ⑥ is
linear , see Figure 48 (Xiu), so the adjustment of (RP]~-RP2) The resistance value can change the output voltage drop U. . The size
is from 『m to achieve the purpose of adjusting the brightness of the electric lamp E.
The larger value of RFI is used to adjust the initial brightness of the lamp. It is a fine-tuning potentiometer. Once set once, it
will not be adjusted again. RP2 is the brightness adjustment potentiometer, and adjusting its resistance can adjust the Z of PSSR. ;
Continuous change between Zn - Ze can make U. Changes smoothly between 3-2] 5V (actual measurement value), that is, the light brightness
changes smoothly. Since the insulation resistance between the control terminals ①~④ and the output ⑤ and ⑥ pins of the PSSR is
1OOMfl, there is good electrical isolation between the manual barrel photopotentiometer and the mains, making it very
safe and reliable to use. The varistor RV is used to protect I and SSR from the impact of power grid surge voltage.
- Analysis of the working principle of the sound and light controlled delay switch circuit
- How to choose the right level of integration to meet motor design requirements?
- How to remotely control devices using ESP8266 and LPC2148
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- Perform surgery on the speaker protection circuit
- Design and manufacture of three-phase motor protection circuit
- Electric vehicle battery charging protection circuit
- An experimental model of an infrared radio alarm
- Homemade anti-theft watchdog
- Differential amplifier emitter negative feedback gain control circuit
- Microwave oven control circuit
- Traffic traffic light control circuit
- Table printing machine control circuit
- How Source Grounded Amplifiers Work
- The simplest single differential OCL power amplifier circuit diagram
- High voltage step-down chopper stabilized power supply circuit
- solid state relay circuit
- Low voltage drop linear regulated power supply circuit diagram using power MOS tubes
- AC controlled solid state relay circuit diagram
