Incandescent lamp life extension switch circuit (3)
Source: InternetPublisher:宋元浩 Keywords: Switching circuit incandescent lamp BSP thyristor Updated: 2021/10/04
It is an incandescent lamp with a two-wire connection method . Its warm-up time is relatively long, so
its service life is quite long.
After closing switch S, only
negative 3F cycles of 220V AC power pass through VD1 and S to make bulb E energize and emit
light. At this time, it is in a half-voltage preheating state. The positive half cycle of alternating current
passes through VD2 and R. , R. divides the voltage to
charge the capacitor (-- until the voltage L at both ends of C rises to more than 3V
, breaks down the voltage regulator tube VS and turns on the thyristor
VT. At this time, the bulb E turns on and lights up.
The circuit half voltage The preheating time is mainly determined by the voltage stabilization value of vs and
the capacity of the capacitor C. The preheating time of the data shown in the figure is about 2s. VT can use micro-triggered unidirectional thyristors
with smaller triggering current , such as 2N6565, MC, R100
type 8 etc. vs is a 3V, 1/2W Zener diode. There are no special requirements for other components.
- DIY a hat with a programmable LED display
- IRS2530D electronic ballast circuit diagram
- LED Flasher circuit using 2 transistors for LED switching
- Driving circuit for driving light-emitting diodes by IR53HD420
- battery charging circuit
- Lighting lamp voltage stabilizing circuit (2)
- Automotive LED driver circuit diagram using LT3486
- Frost alarm circuit
- Small current anti-theft alarm circuit
- Touch lighting switch circuit three
- Analysis of rectifier circuit types and principles
- Chicken supplementary light to increase egg production rate circuit
- Particle clogging alarm circuit of wheat seeder
- Egg heating control circuit
- AC voltmeter
- Domestic KD8041 integrated phase locked loop
- Mixer built with analog multipliers
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Motorcycle flash light circuit
