Driving circuit for driving light-emitting diodes by IR53HD420
Source: InternetPublisher:aerobotics Keywords: led Updated: 2023/01/09
The picture below shows the novel circuit of IR53HD420 driving light-emitting diodes. VDC in the picture is DC 320V. It is obtained from 220V AC through rectification and filtering. The IR53HD420 output produces 320Vp - crimped to a series combination of compact fluorescent tubes and a current limiting inductor Ll, and connected to a parallel capacitor to create LC resonance for heating. Light up fluorescent tubes. And provide lamp current. The device works great. The compact fluorescent tube voltage is typically 150Vp-p. Connect dozens of LEDs (LEDI-LED64) in series. and connect them to a bridge rectifier (D1-D4). At least it can simulate the effect of a compact fluorescent lamp when it is on. The values of Rt and Ct given in the figure make the bridge work at 70kHz. The current provided by this circuit to 64 LEDs is approximately 80mA. The LED current consists of DC plus a small pulsating current. Keeping the pulsating current low is beneficial to achieving high efficiency and extending the service life of the LED. During an oscillation cycle, the voltage at the input terminal of the LED rectifier remains unchanged. Therefore the current in inductor L1 is a triangular wave. This is good for EMC (electromagnetic compatibility). The average LED current equation is IlEDAug=(1/2VDC-NxVFled), (4xfxLl), where VDC is the power supply and N is the number of LEDs connected in series. Vnm is the LED forward voltage drop. f is the oscillation frequency. L1 is the inductance of the current limiting inductor.
- Experiment on realizing photoelectric alarm using photosensitive devices
- TEC laser diode driver circuit
- LED Flasher circuit using 2 transistors for LED switching
- Infrared remote control device circuit
- Corridor automatic light-off device
- Microwave Doppler warning circuit
- Economical and practical delay light circuit
- Two-way electronic music doorbell circuit
- 6-digit cathode fluorescent triode display circuit
- Reverse polarity drive circuit
- Fish tank flashing light circuit
- Digital photoelectric rotation detection device circuit
- LED lighting display detection circuit with overload protection
- Stabilized power supply overload indication circuit 2
- Centralized control of the rescue alarm circuit
- Light emitting diode display circuit one a
- One of two sets of colored light chain circuits that flash in turn
- 60W field effect tube power amplifier circuit
- Light-emitting diode pulse drive circuit using C-MOS NAND gate
- LED flasher using programmable unijunction transistor
