Vibration alarm circuit
Source: InternetPublisher:Lemontree Keywords: Alarm circuit piezoelectric ceramics time base circuit Updated: 2021/02/03
Working principle of the circuit: This circuit uses an integrated circuit ICM7556, two piezoelectric
ceramics X1 and X2 and several passive electronic components to form a mechanical vibration alarm, which can
produce an alarm sound for 1 minute. As long as mechanical vibration is applied to the piezoelectric ceramic X1 ,
a voltage will be generated on the 10 MΩ resistor at pin 6 of IC1 (A), triggering the time base circuit
7556, causing the piezoelectric ceramic X2 to sound an alarm. The second time base circuit IC1(B) generates
a self-excited signal modulated by a low frequency of 5 Hz.
- Smart Farm Design Solution Based on LoRa
- Battery equalization system and control method thereof
- Ways to deliver more than 100A to ADAS processors
- What components and functions does the battery management system consist of?
- How to calculate the power loss of RS-485 transceiver THVD1550
- Telephone cipher circuit
- JC3.5 hydraulic controller and its wiring a
- Thermocouple Temperature Transmitter
- Chinese learning machine disk drive interface card circuit diagram circuit
- One use and one standby constant pressure water supply frequency conversion speed control circuit b
- Simple water level alarm circuit
- Disconnected anti-theft alarm circuit (1)
- Smoke alarm circuit (4)
- Human body proximity alarm circuit
- knock alarm circuit
- Motorcycle anti-theft alarm circuit-b
- Motorcycle anti-theft alarm circuit-a
- Rain alarm circuit diagram B
- Power failure alarm circuit diagram B
- Power failure alarm circuit diagram A
