Three color color changing light circuit
Source: InternetPublisher:D先生 Keywords: led Updated: 2021/08/18
Circuit working principle: lC. It is a decimal counting decoding integrated block. The two NOT gates of IC 2
, resistors and capacitors form a pulse generator. The signal is transmitted to the CP terminal of IC1 through pin 4 of IC
, so that Y0 and Y9 respectively output high level . When Y0 outputs a high
level, the LED directly emits red light; after a while, Y3 outputs a high level, and the LED emits
green light; when Y6 outputs a high level , vs1 and vs2 are turned on, and red and green light up at the same time
, turning it into orange. Light. In this way, red, green, and orange light appear alternately over and over again,
becoming a color-changing lamp.
- Build a Bluetooth-controlled wireless scoreboard
- IR2153 emergency fluorescent lamp circuit diagram
- DCD-1240 multifunctional rechargeable lighting
- Use MC1455PIG to make automatic cycle light-emitting diode circuit
- Infrared detection alarm
- Simple light-controlled street light circuit (7)
- One of the circuits that control one light in multiple placesb
- Remote anti-theft alarm
- Touch/wireless remote control dimmer light circuit diagram
- Reverse polarity drive circuit
- MAX684 charge pump driving white LED circuit diagram
- LED driver circuit diagram powered by solar cells
- Dark activated LED flash circuit
- NE555 typical application circuit diagram (2)
- Ordinary optocoupler isolation circuit
- S8050 low-cost high-performance LED constant current power supply circuit diagram
- LED level meter driver integrated circuit diagram
- Biogas concentration detection line
- DC regulated power supply status display circuit
- 4 and 1/2 LED digital display (DMS-40PC series)
