LED driver circuit diagram powered by solar cells
Source: InternetPublisher:桂花蒸 Keywords: LED power battery circuit driver Updated: 2021/05/29
This figure shows the application of an LED driver powered by a solar cell to an LED emergency flashlight. When the flashlight is turned off, the LTC3536 is in shutdown mode. Its quiescent current of less than 1μA minimizes supercapacitor power consumption when ambient light is no longer available. When the LED flashlight is turned on, the LTC3536 turns on through the SHDN pin to provide a constant load current of 105mA to the LED. The LTC3536 regulates output and LED current to provide 14 minutes of reliable lighting with the supercapacitor charged up to 5V. This guaranteed lighting time of 14 minutes can be extended by increasing the value of the supercapacitor or using a battery with suitable charge control.
![LED driver circuit diagram powered by solar cells](http://www.eeworld.com.cn/circuit/upload/2c1c539366eac6127877261beb59b0d8/a6cc9071c2d97f91a284f35d80a25e04.jpg)
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- In-depth analysis of DC-AC converter inverter
- Fabrication of multi-cell lithium battery charging circuit
- Constant current LED lamp driver circuit with soft start and anti-shock
- Principles and precautions of active discharge circuit
- CNC regulated power supply production
- USB power socket using the car battery
- Design of electric vehicle charger
- LED drive circuit based on switching power supply
- Serial dynamic LED scanning circuit
- LED backlight driver module design circuit
- Ordinary optocoupler isolation circuit
- Three-phase phase loss alarm light circuit
- S8050 low-cost high-performance LED constant current power supply circuit diagram
- 5-point LED driver circuit diagram of HA7666P/TA7667P
- Five-digit LED level indication driver integrated circuit typical circuit
- Biogas concentration detection line
- The equipment runs through Chengdu display circuit
