Digital tube lighting circuit diagram
Source: InternetPublisher:萌面大虾 Keywords: Digital tube circuit diagram 74LS245 Updated: 2020/08/24
After the microcontroller executes the program, the Pl port outputs to the input end of the bidirectional driver chip 74LS245 , which drives each segment of the digital tube in phase. According to the information output from the Pl port, characters are formed on the digital tube to achieve the purpose of using the digital tube to display characters.
The Pl port is connected to the input terminal of 74LS245, and its output terminal is directly connected to each segment of the digital tube. Among them, pin 19 of 74LS245 is called the enable control terminal. When this pin is at low level , 74LS245 transmits data, so pin 19 is connected to the ground wire. Pin 1 is the transmission direction control terminal. When the pin is high level, pins 2 to 9 are the input terminals, and pins 1 8 to 1 1 are the corresponding output terminals. When pin 1 is low level, pins 18 to 1 1 are the input terminals. is the input terminal, and pins 2 to 9 are the corresponding output terminals. In this example, pin 1 of the circuit is connected to low level , and the latter is used for input and output. The common cathode end of the digital tube is connected to the ground wire. This connection method is called static mode.
- How are diodes made using semiconductors?
- How to identify common mode interference? Methods to eliminate common mode interference
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- Simple Wired Spy Bug Circuit Built Based on IC741
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- Diode-based clipping circuit
- DIY a decorative lamp
- Experimental circuit based on 4040 binary adder counter
- Star finder battery indicator circuit
- Circuit diagram of a differential amplifier circuit
- Electronic circuit diagram tips
- Common voltage comparator circuit diagram
- 555 photo exposure timer circuit diagram
- 60Hz time base generator circuit diagram composed of MM5369
- Triode color changing flash circuit diagram
- Remote control circuit diagram composed of CSJ-T300B and CSJ-R02B
- Measurement circuit diagram of differential pressure sensing bridge
- Pressure measurement circuit diagram
- JB35 module external circuit diagram
- Electronic relay driving glow digital tube
