Heart rate detection circuit
Source: InternetPublisher:笑流年 Keywords: Amplifiers power supplies and other power circuits Updated: 2020/10/26
Cadmium sulfide photoresistor CD1 can detect the filter passing through the fingertip. CD1 forms the feedback network of the sensor amplifier. A part of the sensor amplifier, ICA, can generate weak signals, which can be further amplified by the ICB. These signals are often compared with a user-adjustable threshold, and the comparator ICD triggers the switch of the piezoelectric buzzer PZ1.
- In-depth analysis of DC-AC converter inverter
- Driving circuit of switching power supply field effect tube
- Introduction and principle analysis of switching regulated power supply
- Energy-saving motorcycle rectifier regulator
- Use pulse width modulation to get a precise output voltage
- Transformerless AC-DC constant current LED driver circuit
- Boost drive circuit composed of RT8450
- Charging control circuit made by solar energy
- Dynamic power supply for power amplifier controlled by thyristor
- Constant current charger using light emitting diode as voltage regulator
- 90V/10A high power amplifier
- Voice compressor circuit
- TDA2030A subwoofer circuit diagram
- Clamp amplifier circuit diagram
- Cascade MMIC amplifier circuit diagram
- A crystal controlled local oscillator circuit diagram
- Differential bridge amplifier circuit diagram
- Low drift peak detector
- Basic Op Amp Differential Amplifier
- An FM transmitter overvoltage protection circuit diagram
