Low drift peak detector
Source: InternetPublisher:睡不醒的小壮 Keywords: Amplifiers power supplies and other power circuits Updated: 2021/10/13
This circuit uses operational amplifier U1 to compensate for the offset of peak detection diode D1. Ch is the exact peak voltage, and U2 is the voltage follower used to read the voltage.
- Using Lead-acid Battery as Power Source for Walkman
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Switching power supply circuit composition and function introduction of each part
- LNK304 non-isolated LED light string driver circuit
- Voltage-current converter constructed with XTR110
- 0.7~24V continuously adjustable current limiting power supply
- Electric bicycle battery charger circuit
- Adjustable voltage regulated power supply circuit
- Circuit diagram explanation: simple switching power supply circuit diagram
- 90V/10A high power amplifier
- Voice compressor circuit
- TDA2030A subwoofer circuit diagram
- Clamp amplifier circuit diagram
- Cascade MMIC amplifier circuit diagram
- A crystal controlled local oscillator circuit diagram
- Differential bridge amplifier circuit diagram
- Low drift peak detector
- Basic Op Amp Differential Amplifier
- An FM transmitter overvoltage protection circuit diagram
