Symmetrical PWM control ZCS half-bridge converter schematic diagram
Source: InternetPublisher:萌面大虾 Keywords: Half-bridge converter PWM control resonance Updated: 2021/04/08
The symmetrical PWM control ZCS half-bridge converter adds an auxiliary branch composed of an auxiliary switch tube, a resonant capacitor and a resonant inductor in series on the secondary side of the traditional asymmetric half-bridge circuit transformer. The main switch tube not only works in a symmetrical state, but the converter can achieve ZCS of all switches and ZVS of all diodes in the entire load range. Like the symmetrically controlled half-bridge, the auxiliary switch is turned on once every half cycle, using The resonance between the resonant capacitor and the transformer leakage inductance creates conditions for all switching tubes ZCS and all diodes ZVS in the full load range, making it difficult to achieve soft switching under heavy load.
- Analysis of the working principle of switching regulator
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Introduction and principle analysis of switching regulated power supply
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Miniature polarity reversal power supply using MAX1721
- Homemade low-power UPS
- 3~15V 10A adjustable voltage regulated power supply
- Car power 1.5V-12V six-speed converter
- Constant current charger using light emitting diode as voltage regulator
- Adjustable voltage regulated power supply circuit
- Industrial product promotion and shopping guide DC power supply circuit
- High current (4A) switching regulator integrated circuit L296 outputs 5.1 to 40V
- Power supply circuit with multiple outputs (MAX1902)
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
- Super Class A power amplifier power circuit
- PWM control of TDA5142T output stage
- Neon light high voltage power supply circuit
- Inverter power circuit
- 25Hz ring current power supply circuit
- High quality power supply circuit schematic diagram
