PWM control of TDA5142T output stage
Source: InternetPublisher:酷到被通缉 Keywords: PWM control BSP winding Updated: 2020/04/02
Speed digital control circuit. The external PWM signal is input from pin 17.
OTA acts as a level converter to control external transistors. What needs to be pointed out here is that the PWM voltage cannot be directly added to the motor
winding like
the general DC motor PWM control . Otherwise, the PWM signal will seriously interfere with the back electromotive force waveform, making the zero-crossing point impossible
to detect. Therefore, after amplification by an external transistor, a filter composed of an inductor and a capacitor is connected
to control the VMOT power supply end of the integrated circuit at one level. That is to say, the motor windings are still controlled by analog mode.
The braking of the motor is performed by pin 8. When the voltage of pin 8 is lower than 2.3V, the motor brakes
; when it is floating or greater than 2.7V, the motor operates normally.
- DIY a simple fire alarm
- A simple magnetic switch circuit sharing
- Build a glove-controlled robotic arm
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- Introduction to the internal structure of the Delta winding motor
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Working principle of one Xipu STR soft starter controlling two motors
- Squirrel cage asynchronous motor reverse braking control circuit
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Magnetic door and window anti-theft alarm
- Set timing circuit when power is on
- electromagnetic field sensor
- Self-defense anti-riot circuit
- Bone hyperplasia treatment circuit
- Peanut and melon seeds roasting machine circuit
- Farmland irrigation automatic control circuit b
- Mixer built with analog multipliers
- Diode Balanced Mixer Circuit
- Simple AGC circuit in transistor radio
- Voltage series negative feedback amplifier circuit
