Ultra-low quiescent current ZXSC100 application circuit analysis
Source: InternetPublisher:Lemontree Keywords: Low quiescent current application circuit BSP output voltage Updated: 2020/09/29
1. Input filter capacitor, used to stabilize the power supply voltage of the IC and filter out interference signals;
2. Connect to the emitter of the internal drive tube, and connect it to the drive current detection pin RE in low-power applications . If it does not connect to the RE pin in high-power applications ;
3. Output voltage boost inductor;
4. Output voltage-boosting power switch tube;
5. Output boost voltage power switch tube working current detection resistor;
6. Output voltage boost diode;
7. RC frequency compensation circuit, used to stabilize the work of the circuit ;
8. Output sampling resistor to stabilize the output voltage at the output voltage determined by the internal reference stable voltage;
9. Output filter capacitor to stabilize the output voltage and reduce the ripple voltage added to the load.
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Introduction and principle analysis of switching regulated power supply
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Detailed explanation of 5v charger circuit diagram
- Charging control circuit made by solar energy
- MAX1811 Lithium Battery Charger Production
- A low-cost, high-reliability battery charger for electric vehicles
- Circuit diagram explanation: simple switching power supply circuit diagram
- Motor forward and reverse control wiring diagram (2)
- electromagnetic field sensor
- Analysis of rectifier circuit types and principles
- Homemade disinfectant circuit
- High-efficiency speaker circuit for rural stage
- Audio function generator composed of ICL8038
- Capacitive feedback oscillator circuit
- Second-order active band-stop filter circuit
- Power phase sequence display circuit
- Digital stopwatch display circuit
