Op amp impedance multiplication circuit
Source: InternetPublisher:方世玉223 Keywords: Power supply other power circuits Updated: 2020/10/27
As the only standard resistor, the equivalent feedback resistor has a resistance of 10GΩ. Even if the offset voltage is multiplied by 100, the output offset is actually reduced because the output is dependent on the compensation current rather than the bias current. The summary point voltage is less than 5 millivolts.
- Using Lead-acid Battery as Power Source for Walkman
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Basic circuit description of adjustable voltage regulator LM317
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Driving circuit that controls LED brightness using PWM signal
- Transformerless AC-DC constant current LED driver circuit
- Low cost and high performance LED constant current power supply
- Current/voltage conversion circuit using current converter
- Car Audio Power Supply
- Homemade home inverter circuit diagram
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
