Programmable gain amplifier circuit diagram
Source: InternetPublisher:武林萌主 Keywords: Amplifier circuit diagram programmable gain amplifier WIDTH Updated: 2020/06/18
This circuit is a programmable gain amplifier with differential input . 5G4051 is equivalent to a single-pole eight-throw switch. When pin 6 is low level, it corresponds to a state of A, B, and C. When the channel is turned on, it changes by one, so that the feedback resistance changes once, correspondingly The voltage gain changes one value. The status of the two 5G4051s changes synchronously, and the output voltage is differentially amplified by F007.
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- How do Zener diodes protect circuits?
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- Analysis of three simple electronic dice circuits
- Structural diagram and function of sliding resistor
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Touch circuit design and analysis
- Digital number selection machine
- FL52C4 induction electronic greeter
- LA4461N power amplifier circuit diagram
- LA3225T LA3226T audio preamplifier circuit diagram
- AN7173NK power amplifier circuit diagram
- Programmable gain amplifier circuit diagram
- SPT1141/1151 multi-function switch controller circuit diagram
- Nickel-cadmium battery charger circuit diagram
- Constant voltage current limiting charger circuit
- Spike peak measurement circuit diagram
- Multi-waveform signal generator circuit diagram
- Variable gain amplifier circuit
