Introduction of TDA4863J/4863AJ TV field scanning IC
Source: InternetPublisher:走马观花 Keywords: Deflection Amplifier Updated: 2024/11/15
The TDA4863J/4863AJ is a deflection amplifier for vertical deflection systems with a maximum frequency of up to 200Hz. The TDA4863J requires a separate retrace supply voltage (up to 60V), so the supply voltage can be adjusted independently to achieve the best power consumption and retrace time.
The TDA4863AJ retrace supply voltage is generated by internal voltage doubling (the two supply voltages are DC coupled outputs only), so no separate retrace supply is required. Both circuits offer a differential input stage and are well suited for the TDA485X monitor deflection control series. The pinout of the TDA4863J/4863AJ is shown in the figure.
The pin functions are as follows:
- What does a rectifier do? What is the process of rectification?
- How to identify common mode interference? Methods to eliminate common mode interference
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- Causes and solutions for noise in digital Class D amplifiers
- Analysis of the working principle of CMOS/CCD image sensor
- What are the types of commonly used batteries?
- What is a D flip-flop and how does it work?
- Structural diagram and function of sliding resistor
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Make a simple AM radio with digital circuit
- 555 square wave oscillation circuit
- 555 photo exposure timer circuit diagram
- Introducing the CD4013 washing machine timer circuit diagram
- Simple level conversion circuit diagram
- 555 electronic guide speaker circuit diagram for blind people
- Circuit diagram of disconnection alarm composed of 555
- Analog circuit corrector circuit diagram
- color discrimination circuit
- Color sensor amplification circuit
- Level indication circuit
