Switching power supply high voltage constant current source circuit diagram
Source: InternetPublisher:两手空空 Keywords: Switching power supply constant current source circuit circuit diagram high voltage Updated: 2021/09/24
![Switching power supply high voltage constant current source circuit diagram](http://www.eeworld.com.cn/circuit/upload/f876f5953ceb87bb33d52c552120b9d4/a4d91957afdb5913f9f9b1196a3b8f02.gif)
To develop the instrument, we need a constant current source that can generate 1MA current on a resistance of 0 to 3 megohms. We designed one using UC3845 combined with a 12V battery. The transformer uses a color TV high-voltage package , in which L1 is wound with 24 turns of enameled wire around the core of the original high-voltage package. , L3 uses a coil of the original high-voltage package, and L2 uses the high-voltage part of the high-voltage package. L3 and LM393 form a voltage limiting circuit to limit the output voltage from being too high. Adjusting R10 can adjust the open-circuit output voltage.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Driving circuit that controls LED brightness using PWM signal
- Dynamic power supply for power amplifier controlled by thyristor
- LM317 regulated power supply
- Car power 1.5V-12V six-speed converter
- Electric bicycle battery charger circuit
- Constant current charger using light emitting diode as voltage regulator
- MIC4680 constant current charger
- The production of adjustable voltage-stabilized power supply composed of LM317
- A low-cost, high-reliability battery charger for electric vehicles
- What is the difference between linear and switching power supplies?
- Infrared proximity switch circuit diagram
- Switching power supply constant current charger circuit diagram
- Power supply circuit diagram of single wire electronic switch
- Uninterruptible power supply circuit diagram composed of MIC5158
- Switching power supply driver PM4040F application circuit diagram
- Low power consumption induction cooker switching power supply module
- DNC-X50E special switching power supply
- Basic circuit diagram of switching power supply AC input and rectification and filtering
- Three-terminal PWM switching power supply-PWR-TOP200 series and applications 03
