Uninterruptible power supply circuit diagram composed of MIC5158
Source: InternetPublisher:风向西瓜 Keywords: DC-DC switching power supply power supply DC/DC Updated: 2021/08/31
Power circuit refers to the circuit design, circuit form and characteristics of the power supply part that provides power to electrical equipment. The power supply includes AC power supply and DC power supply. Power supply circuits can generally be divided into switching power supply circuits, voltage-stabilized power supply circuits, current-stabilizing power supply circuits, power power supply circuits, inverter power supply circuits, DC-DC power supply circuits, protection power supply circuits, etc.
As shown in the figure below, it is an uninterruptible power supply circuit diagram composed of MIC5158. This circuit uses MIC5158 to control two N-channel MOSFETs as switches to form an uninterruptible power supply. The two N-channel MOSFETs are connected source-to-source, thus preventing current from flowing through their own integrated diodes. The low dropout voltage regulator thus constructed can quickly control battery switching. The most critical function of the AC network cable monitor is to ensure that when the battery is still working online, the output voltage is below the designed limit voltage.
![Uninterruptible power supply circuit diagram composed of MIC5158](http://www.eeworld.com.cn/circuit/upload/53a4ba59a33d887a8573bbc799d7e6e9/aec391597b84905bcb92ca3fec24dbf5.jpg)
- Energy-saving motorcycle rectifier regulator
- Driving circuit that controls LED brightness using PWM signal
- Detailed explanation of 5v charger circuit diagram
- Dual forward converter schematic diagram
- Dynamic power supply for power amplifier controlled by thyristor
- Adjustable regulated power supply with current limiting protection
- 3~15V 10A adjustable voltage regulated power supply
- Car Audio Power Supply
- Adjustable voltage regulated power supply circuit
- MAX1811 Lithium Battery Charger Production
- Do you know about the new high-voltage DC-DC power module?
- The difference between switching power supply and ordinary power supply
- Infrared proximity switch circuit diagram
- DC switching power supply schematic diagram
- Self-switching power supply
- Switching power supply driver PM4040F application circuit diagram
- Switching power supply constant current charger circuit diagram
- Parallel switching power supply for televisions (c)
- 70-watt switching power supply integrated circuit diagram based on KA2S0880
- Typical application connection diagram of TH103
