Circuit diagram of separately excited switching stabilized power supply using single-junction transistor as pulse generator
Source: InternetPublisher:同住地球村 Keywords: Switching regulated power supply regulated power supply circuit pulse generator single junction transistor Updated: 2020/03/14
In the picture: VD1~VD4 and C1 are rectifier and filter circuits, which convert the 220V AC grid voltage into 300V DC voltage. The pulse generator consists of a single-junction transistor VT1, resistors R3, R4, R5, a potentiometer RP and a capacitor C3. Changing the resistance of the potentiometer RP can change the pulse frequency. C4 is the coupling capacitor of the output pulse. Rl and R2 divide the 300V DC voltage to provide a working voltage of 20~30V to the single-junction transistor VTl. VT2 is an inverting amplifier tube, which inverts and amplifies the positive polarity pulse output by the pulse generator, and delivers a negative polarity pulse to the switching tube VT4, so that it cuts off when VT1 outputs a positive polarity pulse.
- What kind of circuit is a voltage regulator circuit?
- Use pulse width modulation to get a precise output voltage
- The constant current source composed of two transistors can drive high power
- LED rechargeable flashlight circuit diagram
- A simple positive and negative power supply circuit
- An ultra-low output voltage regulator
- Power supply circuit that can reduce LM317 ripple
- Homemade low-power UPS
- 3~15V 10A adjustable voltage regulated power supply
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- The simplest switching regulated power supply circuit diagram
- A single-section transistor performance test circuit
- One of the automatic periodic switching circuits
- Anti-theft alarm circuit 2 with warning wires
- Thermistor constant temperature control circuit 2b
- Circuit diagram of separately excited switching stabilized power supply using single-junction transistor as pulse generator
- Zoomlion F-2250 power amplifier switching regulated power supply circuit diagram
- Width-adjustable switching regulated power supply circuit diagram controlled by WS157
- 6A variable output switching regulated power supply circuit
- Single-junction transistor monostable circuit insensitive to bias voltage changes
